5X112 19X8.5 ET30 IN THE FRONT 19X9.5 ET40 IN THE REAR
im just wondering if they will fit? if they do will they rub? will i need spacers in the front? sorry im just a noob with a questions about fitment?
actually i would prefer 18". just wondering about width and et :)
9.5 " is too wide for the rear. What size tires are you planning to run?
on 18" prolly 40 or 35 profile tire and whatever width fits. ------------->
did your ch's fit stock or did you do some modifiying to make them fit?
Need some fender rolling for lowered suspension to fit 255/35/18s. CH offset of 35 is good...
Also needed fender rolling for previous 235/40/18's on 18x8.5 ET 35.
Bruce |
ET 30 on an 8.5" wheel in the front is out there.
You'll probably be past the fender. My wheels are 8.5" wide and ET37 and they're just about even with the fender. I don't rub but I'm not that low. 9.5" in the back is pretty wide too. You definitely won't need spacers cause you'll probably be too far out already.
dont stagger AWD
i'm running that with 6mm spacers in rear
to clear the control arms. Rear rubs on big bumps or really hard cornering, but perfectly streetable (I have eibach springs + bilstiens)
You can stagger AWD just fine if you match rolling diameter. It increases understeer, but looks really mean. |
