6-spd transmission linkage
My shifter linkage is extremely loose!! I replaced the snub mount with an APR branded unit and the ammount of engine movement decreased (no more bucking). How ever when applying/removing my foot from the accelerator my shifter **** travles app. 3/8" - 1/2" (front>back) as it did since i bought it. It is really getting bad; in the morning 2nd gear grinds briefly. Any ideas?
Could be bad motor mounts, tranny mounts, shifter rod bushings, or the shifter assembly could need
servicing.
Please let us know what mods and if the tranny and motor mounts are stock.
FWIW I have the same problem and my motor mounts are slightly shot and my tranny mounts probably are
too!
I have stock mounts and snub, with ASP tranny stabilizer bar.
Judging from how the shifter assembly is set up, your motor mounts and/or tranny mounts are probably gone.
How many miles on the car?
Re: do you habe stock tranny mounts? stabilizer bar ?
I have been busy with work so the repairs are slow...but other than the snub every thing is stock at 87k. >Symptom: when cruising at say 65mph and I up shifting into 5th, if I wait a few seconds after being in gear and then apply some throttle, I will occasionally get a bang from under the hood. >Symptom: After removing the shifter boot assembly i noticed that when acclerating hard/backing off throttle, the shifter linkage/shifter housing has noticible front-to-back movement (it bounces?).
Kingttr
11-16-2007 05:52 PM
sk88erguy
Audi Original "S" Cars
16
02-23-2006 05:59 AM
newblueS4dc
12-11-2005 06:50 AM
gh0st
02-15-2005 07:41 AM
