93 Octane warm-weather FATS, as I commute to work last week ;)
I still haven't installed my new intake manifold and phenolic spacers, IC water cooling and a bunch of other little things... of course my cats are installed and my car was full of lots of stuff. It's a daily driver It's a bit off 94 octane FATS but practically the same. FWIW, my K16 would normally be pulling ~4.0's in similar conditions.
<img src="http://pictureposter.audiworld.com/38083/fatsdata.jpg"> <img src="http://pictureposter.audiworld.com/38083/fatsresults.jpg">
Thanks MarkP for the smooth EcuX-friendly fatscalc
16<24?
I did a few comparison posts. But the main thing is that it spools slightly quicker and flows more at every RPM point.
When K16 level off at 6600 or so the K24 increase right to the limiter. Because of this, I'm convinced I can crank it up more, but 24.5psi at redline somehow seems sufficient to me.
Yep, by quite a bit...
<center><img src="http://pictureposter.audiworld.com/38083/preliminarydata.jpg"></center><p>
Larger inducer and clearancing nets 300rpm or so
This graph doesn't fully illustrate it, but you can see how the low end flow diverges.
how warm of weather? good to hear its running well...
in 85F today with 95 oct i pulled a 3.78, not too shabby for stock ics. I hate that my misters are broken too, its just straight up heat soak. 20PSI BTW
85 too :) 95, nice octane!
I still have to do some "real" FATS runs and use some of that 100oct nectar around here. It should be pretty brutal.
Those stock IC's recover pretty quickly at speed. Honestly, on the FATS front I couldn't prove data-wise that the upgraded ones helped me on K04.16. On the 1320 they were worth a solid .2 though
