Buying a 2002 S4, quick question
Old 11-05-2015, 09:53 PM
paully's Avatar
Default Buying a 2002 S4, quick question
I am buying a silver 2002 S4 this weekend and the VIN check confirms its a one owner, has no dents and is really in prime shape. It only has 99K miles, and has reciepts for recent tires, timing belt, brakes including rotors and a few other things. He is a trustworthy guy, I know him threw friends but I know this forum has talked about this error code but I am very non-mechanical and I am just trying to evaluate my cost and risk with this. He advertised it for $6K but said he would take $4k because he needs it out of his garage.
Here is what he says, "Check engine light goes on and off periodically. Just passed admissions 5 weeks ago and the light was off but now it is back on. The code that get tripped is P0421 and P0431 -bad-cat. I have not modded the car in any way, it has been serviced at the dealer. Most people just put a spacer with there O2 sensor to the code off but I have not done that.
So I am sure this is a common question but it isn't clear to me if I should be planning on $2K repair for this or if it's $200. This car is nice, he is being fully transparent. I should also mention that he said there is a light showing that a headlight is out, but both do work and he also say's that the back right brake light isn't working and it doesn't appear to be the bulb.
So, should I be sweating? Any help you can give me in terms of estimating repair cost would be appreciated.
Old 11-05-2015, 09:55 PM
paully's Avatar
BTW, I am flying to buy this car in Portland and driving it back to Boise on Saturday, not sure if this error code would be an issue for a 7.5 hour drive?
Old 11-07-2015, 10:53 PM
wilson94t's Avatar
The codes indicate that the 02 sensors are not reading within defined limits. The car may pollute more than it should but there should not be a mechanical issue. Still, you should not drive too hard in a car that you don't know, especially at higher elevations.
FWIW, A typical mechanic response to these codes is to replace cats.
Since you're new to the car, you may want to read up.
https://www.audiworld.com/forums/s4-...00-s4-2877589/
Old 11-09-2015, 07:26 AM
massboykie's Avatar
Originally Posted by wilson94t
...Since you're new to the car, you may want to read up. ....
Three more!
http://www.vaglinks.com/Docs/Audi/B5...Newbie_FAQ.pdf
http://www.vaglinks.com/Docs/Audi/B5...uyersguide.pdf
http://www.vaglinks.com/Docs/Audi/C5...uying_Tips.pdf
Cheers
Massboykie
whansen
06-16-2011 03:48 PM
raddox
08-03-2009 05:00 AM
jmurine
Audi allroad
03-04-2009 02:31 AM
ARK
03-01-2005 09:00 AM
brakeco
SoCal Discussion
12-04-2003 11:06 PM
Quick Reply: Buying a 2002 S4, quick question
