ABS kicking in too soon?
I have had my S4 for a few months now, and it seems to me that the ABS kicks in well before lockup of any of the wheels, significantly hampering the braking performance.
I am very disappointed in the amount of braking force (and the subsequent amount of braking distance) on my s4, and I am not confident that I am actually getting the full braking capability of the tires (the pirellis, if it matters).
Is there any way that the ABS can be tuned? Is it possible for it to be "out of adjustment"? I would think that ABS wouldn't kick in unless lockup was detected on at least one tire - but I don't hear any tire squeal from any of them. I have a '01 tip, so I have ESP - maybe that is causing the problem - but it doesn't go away when I use the ESP disable button. Is there any way to disable ABS so that I can see how threshold braking compares to what ABS thinks the threshold is?
Any thoughts or info appreciated.
i got an appointment.
Its two weeks away. I know for a fact I'm down on power as a E36 328i took my from about 35mph on to 110mph. It wasn't funny but embarressing. I am thinking that the MAF or O2 sensors are okay when the car is cold/cooler than normal driving temps. Once it heats up to normal temps, then its sluggish. I'll keep you updated.
The check engine light disappeared two days ago, I hope the DTC's are still there.
well...
I think it all depends on how you brake... I've found that I can brake pretty deeply before the ABS kicks in by quickly applying the brake, but not so hard/far that it kicks in the ABS. It takes some learning.. try it someplace over and over until you get an idea of where the threshold is.
I think it's because the pads are new...
I noticed it too when I first got the car. The brakes squeaked and ABS kicked in early. After a few months and hard braking too. It's fine now.
Try a few hard brakes to see if the problem goes away.
ABS woes... first brake pedal push when driving car - feels hard, engages ABS sometimes... light on/
aerohr
06-04-2006 05:06 AM
A4AdMan
02-01-2005 04:58 PM
