Accessory mode stopped working, when I turn they key off all power is gone, no radio no windows..etc
After shutting of the car and removing the key the windows, roof..radio etc should continue to work.
It no longer does, Thoughts?? Thanks (And I did STFA_ |
My radio works when keys are removed. Windows and roof work (closing only) when keys are...
still in the ignition but in the off position after I shut off the engine. Windows and roof will not work if I turn ignition off, open the door and then try to close windows or roof.
Your radio should work regardless if keys are in or not. Not sure if the above answers your questions. |
OK, After the car is shut off key removed but door has NOT been opened my windows and roof will no
longer work not will the radio. It all used to, I often shut the car off and than close everything.
Hmmm, wonder if it's related to a fuse of some sort...will have to defer to the pros on this board.
Was thinking maybe a relay of some type.. but I am clueless on this one :)
Anyone? I so DONT want to go to the stealership
