Alright need help making a decision IC's vs Suspension
Alright I'm running Koni/Intrax set up and it feels great and does well in boston but its really to soft. It gets beat up pretty bad everytime i floor it. People have sworn i've hit my tow-hook on really good launches. The car just is way to soft forward and back. Now I have stock IC's. But I'm having a hard time being convinced that RS4 Ic's will really make a big difference. The question is which one do you think is more worth while to the overall performance of the car both at the strip and in daily life?
My 2 cents on the IC's..... When I upgraded my IC's to the RS4's I noticed reduced turbo noise....
so I assume they are not working as hard due to the reduced pressure loss. When I went to the dyno with the RS4 IC's I did not get any heat soak as oppossed to the S4 IC's I lost 30 hp over 5 runs. You also have the RS4 bumper that will mate to the RS4 IC's perfect.
Suspension ?? why not adjust your KONIs
If I had to drive in Boston all the time I'd want a soft suspension
Those roads are really bad - they are too much for the combination of stasis 600/700 and my dainty butt
As for ICs I wouldn't pull the trigger until there's more info about AWE's
