Any problems if I have wider rear tires?
235 rubs badly even w/ fenders rolled and plastic cut off.
Lowered with H&R sports + Bilstein shocks
I'm gonna get two 225 for the front.
Re: Any problems if I have wider rear tires?
I don't think width is an issue, circumference is. The rolling circumference of all four tires must be the same to not damage the quattro system.
the fronts & backs will (most probably) wear unevenly. you won't be able to rotate the tires.
you need to run the same rolling height(within 1-2%) front and rear!
i have 225/40/18 fr and 255/35/18 rear for over a year now and no problems as a matter of fact with a neu 22mm rear swaybar the car is basically perfect... heres how to calculate rolling height
width(MM)/25.4*sidewall height(mm)*2+wheel size (inches)
225/25.4*40*2+18=25.08 inches
255/25.4*35*2+18=25.03 inches
in your application 235's adn 225's won't work you need a 205 front tire or a 265 rear tire to pull it off!
