Anyone familiar w/ trans rear output shaft seal replacement? Is this A8 writeup close enough
to get me through the job on the S4 (exhaust differences aside)? I don't have access to Bently so I've been searching archives (amongst other places) in preparation.
<a href="http://www.audipages.com/Tech_Articles/auto_transmission/transealreplacement.html">A8 Output Seal Replace</a>
Any tips are much appreciated.
Does the Torsen housing need to be removed in order to remove driveshaft on a 6sp? It's mentioned
in this post, vaguely:
<a href="https://forums.audiworld.com/s4/msgs/2300806.phtml">seal replace post</a>
No no no...Just unbolt the driveshaft from the output flange on the back of the transmission, and
then remove the output flange from the transmission by removing it's retaining bolt.
Here's a good diagram of the action:
<center><img src="http://pictureposter.audiworld.com/110556/v39-1873.jpg"></center><p>
#4 is the seal in question. They recommend using a press but you should be able to improvise with everything still on the back of the transmission.
audikillsbmw
03-04-2007 08:15 AM
FAS4WD
01-31-2007 08:54 PM
TerminA8r
10-28-2006 05:10 AM
audijim113
05-13-2006 06:42 AM
