anyone got suggestions on a good pump to use for pressure testing?
i'm gonna go search jcwhitney and mcmaster -- was just hoping someone has already BTDT.
tia |
my 6hp 30 gallon craftsman compressor works well! :)
Or you can take a normal portable air tank (like those used for autox'ers racers for their tires).. Add a regulator to it so you don't go over 10psi, go to your local "good" gas station and put 120 lbs of air pressure into it and your good to go!
i have a regular tire thingy with a gauge, but the tire nozzle thingy won't go on the compression
tester's nozzle thingy. know what i mean?
guess i should prolly hunt around sears first. |
Maybe somethink like this?
<center><img src="http://pictureposter.audiworld.com/26345/airtank.jpg"></center><p>2k2s4 pressure tests his car, seems to work nicely.
yeah, lightweight's got one of those suckers, but he doesn't have a gauge that shows how much
pressure is currently in the system.
You could try this one :)
<center><img src="http://www.homestead.com/baltimore2/files/breastpump2.jpg"></center><p>
Im working on getting a second gauge.. Just give me some time..
Lat is fvcking hilareous
Any compressor out there can handle it. But might as well pick something up that can do more...
Like run air guns and whatnot.
Be carefull
I blew the damn thing off even tho I set the regulator for 15 psi. They just don't work that well at low pressures. Set it at 5-10 psi and SLOWLY crank it up.
