Anyone using a Mahle OC 51 oil filter? Huge sucker, holds like 1L of oil.
Even has a fitting on the end to allow you to twist with a screwdriver for leverage when removing it.
I asked a local shop for a 2.7T filter, and was given this. I've always used dealer filters and exact Mahle/Mann OEM-replacement filters, but I was told this one was a universal fit.
A larger oil capacity can't be a bad thing for this engine?
<img src="http://gallery.hardocre.net/main.php/d/3378-1/IMG_0238.jpg" />
<img src="http://gallery.hardocre.net/main.php/d/3380-1/IMG_0240.jpg" />
i used those until i put an oil cooler on my car
the shop i worked for uses them on most longitudinal 1.8T/V6 applications. i think benefits would be negligible, but it cant hurt
Looks like the one I use on my wife's Passat 1.8T
In that case, the screwdriver thingy comes in really handy because the filter is in a dumb@ss spot and it's hard to get other tools in there.
Yup it's for the 1.8t when they had sludge problems.
I've had a few on my car and it wasn't difficult to get off and on. You'd need a pretty thin filter strap to slip over it though. And yes, it's a big *****.
well, that, and there's one other concern with using that larger filter
it has a bypass spring set at 3 bar, where the stock filter is set at 5 bar. (I think those are the right numbers.)
So, in theory, the larger oil filter will let "stuff" by quicker than the stock one.
LEH82
19
05-18-2008 08:46 PM
98Blue
05-20-2002 06:24 PM
Sammay
04-24-2001 12:16 PM
