Anyone using the SDS wideband O2 sensor?
$399? The Innovate Motorsports one is nicer than that and is $350
<ul><li><a href="http://www.innovatemotorsports.com/products/lm1.php">http://www.innovatemotorsports.com/products/lm1.php</a</li></ul>
That ones cool, I was thinking of getting this for my center vent. Just to see how well it works.
<ul><li><a href="http://prostreetonline.com/buy/aem_uego_controller/30-4111/">AEM UEGO</a></li></ul>
Innovate makes a gauge version as well. Its $400.
Another option to consider.
BTW, did you figure out the manifold vacuum stuff yet? I need to do that at some point.
-Dave Pramanik<ul><li><a href="http://www.innovatemotorsports.com/products/xd1.php">http://www.innovatemotorsports.com/products/xd1.php</a</li></ul>
Do you think there's THAT much of a difference between the two. Basically...
I'm looking for something to just throw in the car to tell me if I'm running lean/rich. I don't need all that adjustment stuff. Cause I'll adj. it through lemmi or whatever. Plus I kind of like the look of the AEM better. I also won't use the record feature that Innovative has. But will one measure better than the other, etc. Your input is appreciated....On the mani., we looked at some schematics and I don't think I'll be using some of the piping off the Allroad mani coming off the back. I'll just run the pipe that goes to the front to the F-hose from the EVAP straight into the rear of the mani. with a bleeder valve between the mani and EVAP cannister. Then from the brake booster/vacuum to the rear of the mani will be another and the last small nipple will of course go to the FPR. Then in the front just run a hose from the green bleed valve to the manifold by the tb like the 2001.5-02's. That should do it. Then replace all my corrugated plastic pipe with rubber hose to eliminate any potential boost issues. *PHEW*
Probably not that much of a difference. I have the innovate one (the meter, not the gauge) and it
works well.
If you take any pics of your hose routing setup, please share them with me.
-Dave Pramanik
-Dave Pramanik
I will...that is IF I swap it now. I just came across the car I've wanted for quite a while, so I...
may not need to do the swap! 2001.5 Laser Red S4 Avant! If things go right, the Imola will be no more! We'll see what I can do with the dealer. I'll keep you posted though.
Biscuit141
Audi 100 / A6 (C4 Platform)
05-20-2004 07:59 AM
BaltoB490S
12
05-01-2003 03:59 PM
