ATTN: nasa racer...question on turbos....
when the turbos started making their fatal sound...
they were showing full boost and requested vs. actual matched pretty well (Frank data logged it). Now today...when I lost boost the turbos WERE sort of able to nearly make full boost but it was clear they were working really hard and not quite cutting it...HOPEFULLY this indicates a leak and not some catostrophic failure of the SECOND set.
When you have enough problems with an S4 you realize the VAG only tells you you just HAD a major problem..."engine fell out error" or "oil all over your windshield because you just threw a rod error". You can have ALL SORTS of problems and the car will appear to be normal on the VAG.
roman_0028QMS
14
08-14-2005 08:05 PM
roman_0028QMS
22
08-14-2005 04:34 PM
EasTTcoasTT
09-04-2003 11:02 AM
