Audiworld CSI, DTC code investigation needs your help!
2000 S4 6-Speed
91,000 miles
Just recently did timing belt like 3 weeks ago. We noticed that i was only boosting 12psi. Changed out my DVs to 710n. Now I can boost up to 14-15. I usually can hit 17psi then taper to 15psi.
These two DTC codes pop up immediately, even after clearing them out. I was wondering if i did my timing belt wrong. We didn't use a cam lock and only marked the gears onto the block.
I've already pressure tested to car for boost leaks. No leaks, just gurgle noise from the oil. I also sent my abs module into modulemaster for repair. No more abs light and the abs works. Any ideas on how I can rid of these error codes? Thanks
17800 - Camshaft Position Sensor Bank 2 (G163): Open Short to Plus
P1392 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
91,000 miles
P1392 - 35-00 - -
P1606 - 35-00 - -
Did not use Cam Lock Bar. Made markings instead. Turned crank a few times and the markings lined up.
I even made sure I turned it in the right directions... So I assumed I got the teeth on right.. Am I wrong to make such assumptions? Should my car be boosting up to 14psi if i was even a little bit off?
Any suggestion on me checking my work without use of lock bar? and without using the markings I made?
Thanks.
Thanks.
After verifying cam sensor is plugged in, is there a way for me to log the cam sensor to see if...
dead or not? should the camsensor on bank 1 and 2 read the same values at all times? So if one side is out of whack we can conclude that it's bad and need replacement.
don't really wanna do a swap and check.. rather datalog it.
Ray Khan
09-17-2018 03:23 PM
Mikey'sS4
VAG-COM Discussion
9
07-25-2011 03:13 PM
My2ndS4
08-10-2005 02:44 PM
