AWE DTS INSTALL HELP NEEDED
I started installing my DTS today and noticed a major problem I thought some of you might be able to help me out with..
The aluminum plate in this picture does not bolt up to my transmission.
<img src="http://pictureposter.audiworld.com/12268/alplate.jpg">
The two holes on the tranmission are spaced much further apart than the two holes on the plate that take the tapered screws.
<img src="http://pictureposter.audiworld.com/12268/twoholes.jpg">
Anyone experience this problem? Did I read something wrong in the directions? Strangely enough the two outer holes on the transmission seem to bolt up to the aluminum plate perfectly. Is this plate only used on the A4 and maybe not on the S4? Just want to clarify before I continue..
thanks!
thanks!
You use the outer holes on the S4. They are threaded, but the bolts pass through it...
and screw right into the trans. Makwe sure to run a thread chaser (tap) through the threads to get the rust out or else you won't be able to tighten the bolts down.
Beergoggles
05-29-2008 07:47 AM
VandyS4
04-20-2005 05:01 PM
markbradford
02-13-2002 02:07 PM
