Big thanks to VR_Life for his help sending my fueling, cooling + brake stuff.
It only took fedex one week to get the two boxes to my door! It usually takes the same from Germany so it really went well this time ; )
I think I'm going to install the adj. FPR first to get some FATS comparison and after that the rs4 ICs and then the bluetops + rs4 maf housing.
The innovate LM-1 was bigger than I had thought but will come very handy when I'm dialling the fueling parameters later this spring. BTW, we still have about 10in snow + freezing weather.
Brakes (front first, rear later) need to be installed in a few weeks also as my passenger side front brakehose had a small tear(not leaking) so it didnt pass inspection. BTW, those ECS rear rotors look HOT compared to stock minidisks!
I also had some trouble gettin the exhaust CO level low enough, but luckily the inspector had some time to keep the rpms at 2500 so the CO level finally lowered to acceptable level (EURO 3 specs).
Anyone else had any trouble with LaBree CATs and MOT?
David, let me know the amount I owe you so I can paypal you!
My pleasure - I know how hard it is to get stuff from outside the US
It would be good if US dealers/disties/tuner made it easier for folks overseas.
Getting away from USPS is of course the first smart move :-)
I don't know how much the Cats help with CO, isn't that more likely a problem of running too rich ?
I need time to sort through the invoices and figure out how much, hopefully get more time in April.
ImolaPR
12-04-2005 09:18 PM
Stätus Josh
09-06-2001 06:36 AM
LCP
05-21-2001 11:35 PM
