BiPipe leak question:
For those that have found pinhole leaks - what/where was the location? I just cleaned mine(thx again Ed), lightly sanded, sprayed on 2 coats of an epoxy primer/sealer and repainted it engine enamel black. Did not see any suspect areas but would rather adress now vs when the K04s and all the other stuff goes on. TIA.
I found two leaks in mine
Very small, pinhole is a good term to use...
One on the passenger side where the BPV tube was attached.
The other was on the drivers side where the timing belt cover bolt hole is located.
schnitzelboy
12v V6 Discussion
12-30-2005 12:07 AM
AudiS4guy - NorCal
04-16-2005 09:01 AM
AudiS4guy - NorCal
11-19-2004 01:54 PM
JAH1
08-27-2004 12:56 PM
