Blinkers not functioning - postive its a bad relay - need some help here
Who here has dealt with this before? I know some time ago I saw someone with the same problem as me.
The blinkers started sticking awhile ago, I had to manually click them till they started going again. But now they click for half a second and don't go on at all. I need some help here. Anyone know which relay it is, part number, anything? Thanks!
Check your hazard button...
I had this happen to me couple days ago and i checked the hazard button, which is part of the relay also.. I just checked the connections on it and it all worked again, give that a shot if not you might have to replace it.
Re: Blinkers not functioning - postive its a bad relay - need some help here
relay on the instrument panel - pain in the neck to get to. It is not the same relay as the emergency flasher. Relay itself is around $35, but labor is high, or if you do it yourself, you'll have to remove the instrument cluster. Which means removing steering wheel, which means deactivating airbag. If you don't feel comfortable doing that, go to dealer or better Audi specialized service.
spiralsmurf
Audi Original "S" Cars
08-04-2006 12:51 PM
where is the hazrard relay located at??? my blinker stays on, dealer said replace hazard relay. help
Azncrombieguy
02-13-2004 09:55 AM
Kirath ¾-B0§t0n
04-30-2003 07:27 AM
