Boost leaks and samco tbb q's
Old 04-17-2005, 10:40 AM
DocWyte's Avatar
Default Boost leaks and samco tbb q's
Finally got around to pressure testing the system today and found quite a few leaks. Surprise, surprise.
I have two leaks at the y-pipe where it goes into the rubber hose that branchs off to the bpv and turbo inlets. I still have the factory pinch clamps there and need to switch to t-bar or worm clamps. Anyone know what sizes I need? The bottom one looks smaller than the top one...
Also found I had a leak in my samco tbb where that sensor mounts in the top. If I take out the two allen head screws holding the bracket in, the leak goes away. Will I blow that sensor out of the tbb without the screws? I'm uncertain, I pressure tested to 15psi and it was holding, but I wanna make sure. Is this a typical problem with the samco tbb? The screws torque the bracket over and pull the sensor up out of the tbb...
Old 04-17-2005, 11:53 AM
Gator Al (Al)'s Avatar
Don't know about the tbb, but the leaks before the turbo aren't the end of the world...
Old 04-17-2005, 12:19 PM
Junior Member
Blue2's Avatar
Default This might help
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1968154.phtml">https://forums.audiworld.com/s4/msgs/1968154.phtml</a</li></ul>
Old 04-17-2005, 02:09 PM
M3KILR's Avatar
bend that bracket a little so it doesn't pull it
Old 04-17-2005, 03:35 PM
DocWyte's Avatar
Nope, those are for RS4 parts...
NogaroS487
01-21-2010 06:32 AM
eldoj
03-11-2005 10:23 AM
SkiBum1
08-06-2004 01:09 PM
S4stylin TMK
05-21-2002 06:08 AM
Steve in VA
04-01-2001 08:56 AM
Quick Reply: Boost leaks and samco tbb q's
