Brake upgrade time...
... I severely warped my rotors, and I ate through more than 50% of the stock pads at PIR today (Tuesday).
We've got an Audi day coming up at SIR on Monday, so I don't have much time to do something for my brakes.
Seems like a bad idea to just get more stock rotors & pads as I'll probably warp them on Monday.
Is it possible to just get some different rotors and pads that will be better suited to track use w/o having to replace the calipers (which seems to be where the huge expense of brake upgrades comes from).
I'd like to do a serious upgrade eventually, but I think that's probably more expensive then I really want to spend this week .
...Jason
'00 Nogaro/Silver
temporarily almost stock again
...Jason
'00 Nogaro/Silver
try Pagid pads, see Stratmosphere, I've made it through track days with these
no rotor score, no warp (if I cool off the brakes). They aren't as good as the STOPTECH or others but its an improvement
If these are the MTM Pagids, I agree. Best bang for the buck
Makes the next step way too expensive, though, not much gain available over these, other than duration, I suspect these will overheat on heavy track use.
LOTS of dust, too!
LOTS of dust, too!
glad it worked for you, some just don't want THAT "upgrade" (unless you're fixin' it later!)
besides... i cost a lot, and you can only use it once, and you can rarely get a Chevy van placed properly for corner entry braking, and then there's the areodynamic effects from this....
winderBABLE
winderBABLE
Let's be realistic...
You can spend $3-$4k on a F brake upgrade and still warp your rotors. You'll just be warping more expensive rotors. Unless you find a way to get air to the brakes--a lot of air--your 3,600+-lb. car is going to find some way to overheat your brake system. I just put Alcons on, and I'm still worried about warpage until I find a way to run hoses to the brakes.
Lee in D.C.
Lee in D.C.
