Can I lower the boost using Lemmiwinks?
Scenario: 12 hour endurance race. Reliability wins over speed. Would lowering boost using Lemmiwinks work? Or would it sacrifice driveability?
Tomasz |
suing? No. Using, Yes. :P
SEL scaling.
-Dave Pramanik |
Yes, channel 12.
Go do something
Use the MBC instead, worst case you'll run a little rich.
Ummmm....?
Patrick's friend?
I KEEEP doing that!
yeah, I though I'd hang here today. Feel like I've lost touch since the segregation...
We UrS-boys are the stepchildes...
eh.. MBC gives you too much of on/off throttle feeling...
just can't control the wastegate as fast, or as properly as the ecu.
sure, it works. just feels weird in daily driving and when not going WOT. get an electronic boost controller if you really have to. those are good. greddy profec b or other |
If you put it in parallel and set the MBC threshold below the N75 threshold...
driveability should be the same, but the MBC will limit the maximum boost.
-Dave Pramanik |
