Can I be sure it's the ABS Module? Rough Road Fault
Old 06-29-2005, 02:54 PM
GruvenS4's Avatar
Default Can I be sure it's the ABS Module? Rough Road Fault
I've had the ABS BRAKE light on for a while, started after a track day, and it's on about every time I turn on the car. Occasionally, it's intermittent.
I VAG'ed it, and it said that it was the ABS Rough Road 1606 Fault code. From searching through the archives, it says that that is usually the ABS module gone bad. I want to be sure before I go to the expense of buying one.
If I do have to buy one, I will probably either go to the junkyard, or have it rebuild by "module master?".
Any advice for me?
FYI, 2000 S4, 6 spd, 80k miles.
Old 06-29-2005, 03:07 PM
lou0000's Avatar
Default Had that same fault code, replaced mine w/ used one from a junkyard
cost was $350 for the whole unit. Dealer wanted over a grand. dont forget to bleed the brakes if you DIY.
Address 01: Engine
Controller: 8D0 907 551 B
Component: 2.7l V6/5VT G01 0003
Coding: 06651
Shop #: WSC 09110
1 Fault Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
Readiness: 0000 0000
Old 06-29-2005, 03:23 PM
GrandPaJohn's Avatar
Default I'd bet on bad electronics. No need to replace the entire controller.
Just send the electronic module to modulemasters.
AudiSportB5S4
10
05-05-2008 11:25 AM
jjgs4
11-20-2007 09:22 AM
audilogue
VAG-COM Discussion
12-15-2005 01:59 PM
S4MarkS4
12-09-2005 12:14 AM
SpfldS4
11-02-2004 04:56 PM
Quick Reply: Can I be sure it's the ABS Module? Rough Road Fault
