Can Lemmiwinks be used to disable the vehicle?
Old 08-29-2006, 02:00 PM
AudiWorld Expert
Mirror|rorriM's Avatar
Default Can Lemmiwinks be used to disable the vehicle?
I have to leave my car outside for a bit over a week while I'm a few thousand miles away. Is it possible to use Lemmiwinks to disable the car?
Old 08-29-2006, 02:02 PM
Mike2kS4's Avatar
Yea, you can...but an easier way would be to just yank the ECU.
Old 08-29-2006, 03:21 PM
AudiWorld Expert
Default Is there a documented way to do it with Lemmi?
I think using Lemmi would be easier than reaching the 5th screw.
Old 08-29-2006, 03:34 PM
Mike2kS4's Avatar
Default Well, I'd use adaptation channels in VagCom.
There's lots of ways you could make it "not run" via lemmitweaks... but I'd prefer to pull the ECU.
Old 08-29-2006, 04:49 PM
archimense's Avatar
You can take the ECU out without removing the fifth screw.
Old 08-29-2006, 06:27 PM
Member
sj6sp's Avatar
Who leaves any of the screws in?! Lid stays put on its own if you press it in.
Old 08-29-2006, 09:28 PM
Member
PSmalls::AnalRetentiveNumbNut's Avatar
Default Care to share? You're starting to sound like EF. :-/
I can really only think of reducing SEL like mad.
What happens if you try and pull a crazy amount of idle speed? lol
Old 08-29-2006, 09:34 PM
Mike2kS4's Avatar
Default Damn... that hurts teh nutz...
And if you asked nicely and didn't liken me to EF I would share... since you took the low road I'm keeping quiet until you figger it out yourself :P
Old 08-29-2006, 09:38 PM
Member
Default OK, it's official...you're talking out of your *** and don't know.
Seriously, just spill it. How many more times do I have to insult you? :P
Old 08-29-2006, 10:00 PM
Mike2kS4's Avatar
Default LOL... Man,
Do I need to spoon-feed it to you: Recode for something it isn't. I would rather pull the ECU, because if I forgot and just turned the key it could be bad... but prolly not.
Quick Reply: Can Lemmiwinks be used to disable the vehicle?
