Car is totally dead; battery is fine. How do I track down the problem?
Old 04-24-2009, 11:56 AM
  #21
complacentsee's Avatar
Jesus, well I'm in IN so that's not going to happen.
Old 04-27-2009, 04:14 AM
  #22
pink shrimp's Avatar
stories like this ( Car wont start at all for unknown reason-which occur every now and then on the forums) make me really wonder about my car. I have not had any issues like this yet , but what if one day I did on the way to vegas, or to work...
well it sounds like you found the culprit though, if retightening those wires down allowed you to start finally, it must be related to those wires
Old 05-29-2013, 05:37 PM
  #23
srlbotanical's Avatar
I don't know if this was the same problem as the original poster, but I had a similar issue and figured I'd share what I found.
I came home from work tonight, car has been running great. went in the house for something and when I came back out the car was totally dead, like someone flipped a switch. No lights, no dash, my key fob didn't work, nothing.
This is what it was:
The positive battery post has a secondary hook-up that runs through the fire wall to power the fuse panel, etc. This secondary hook-up has a 150 amp fused link that had a crack and was over heating...
I hope that helps someone out when searching in the future.
Steve
Old 08-20-2015, 09:08 AM
  #24
Gerald Hafen's Avatar
Default No power to anything
Hoping you could help where exactly is the secondary hook up is it on the firewall on the inside or on the outside
Old 12-04-2018, 03:12 AM
  #25
BggeorgeS8's Avatar
Default 2009 S8 DOA (Dead On Arrival)
Read thru the forum, thanks guys for the info valuable! Does anyone know where this “secondary hook up” is located for the positive battery post? Arrived back to Airport got in car push start and nothing! DOA! Car still parked in airport garage not accessible by flat bed tow truck need some help with pin pointing this issue, thanks!
Old 02-12-2021, 04:47 AM
  #26
Michael Saez's Avatar
Default Car is dead just
My 2012 audi A4 sline My car is dead just like yours was. Was driving just fine went to car wash washed the engine then moveit to a parking space to dry it off. Was drying it and lisoning to the radio when it just shut off no power to ignition has a push button but can't seem to get any power to it .. trunk,key fob doesn't work the head light don't go on........ I just lost power to half of the car need help please
Old 03-10-2021, 11:12 PM
  #27
Vurre's Avatar
I made an account here just to say thank you so much for showing this 150A fuse on the battery, i proly would have found it sooner or later but i put a few hours into looking at what it could be. and since its my first audi i didnt know any common issues. this saved my day. so thank you sincerely for this.
shoecanvas (03-21-2021)
Old 04-19-2022, 02:54 PM
  #28
Kandi's Avatar
Default Battery gauge fuse?
Originally Posted by NiceS4
What would I check for on the ignition switch? I presume it's not as simple as taking it apart and ::whoa:: I will see what's wrong with it?
What is the fuse number that controls the battery gauge?
Old 05-02-2022, 02:42 AM
  #29
Chad Hinz's Avatar
Nope, nothing works... keyless entry, all lights, etc... so what now?
If nothing worksits a bad ground somewhere...if you have power replace ign. Switch first
Dr.Aronis
34
03-24-2018 10:30 AM
steelhead
10-25-2010 02:23 AM
brunnhizzle
10
09-17-2008 04:07 AM
JustinMarkVII
03-08-2005 08:11 AM
Khris
Misc. Models Discussion
12-17-2000 11:49 AM
Quick Reply: Car is totally dead; battery is fine. How do I track down the problem?
