Cheapest way to go full stage 3
Iam looking for the best and most cost efective way to finish out my B5. I have K04's full exhust and IC's and a south bend stage 3 clutch Now all I need is the fueling
I have heard of a home brew kit and was thinging of going in that direction but I dont realley know were to start or what i realley need The car is a 2001.5 Avant Thanks for any and all help Matt |
the main components are some RS4 fuel injectors and intake components as well as a higher capacity fuel pump. You will need to get your ECU tuned as well.
I would just grab an off the shelf RS4 kit from one of the major tuners - this is probably the easiest and most tested method and not all that expensive really. |
I was thing of doing that but i heard the there are guys doing home brew fueling for way cheper than say a AWE or Vast kit that is runing like 2k
I guess it's possible, but I can't imagine it will be significantly cheaper. The higher capacity injectors are $100 plus a piece, and you'll need 6 of those of course. Then there's the pump, RS4 airbox and intake components...Even if you get a good deal on each individual component you still have to pay someone to do a custom tune.
But don't take my word for it - I haven't done any research. I'm just saying the parts cost so and so much, and in the end how much less than 2k can it be? |
$100 a peice for injectors. You Lie.. maybe for some fancy 60#. But you don't need that.
I would think about picking up a used fueling kit from a major vender, lots of savings to be had. |
http://homepage.mac.com/edyjun1/S4/index.htm
And click on homebrew. Other sections are also very informative, like injectors and MAF. Apparently you can make your own MAF housings for couple of bucks etc :) |
Ohhh, legit RS4 injectors. I see. why would anyone get them? they are double the price of better injectors. I thought you ment the size of the rs4 injectors. mah bad brah.
They are just OEM Bosch injectors @ RS4 specs. Direct OEM Bosch replacements for stock s4 injector run $130 a piece as well. I have not seen a reliable injector for under $100, not even for my old 1.5L honda civic. If you have a source for cheap and reliable injectors or even 60# please to be showing my good sir.
I will strongly encurage you not to use siemens 60#s.
