checked out that salvage S4 yesterday...
<center><img src="http://pictureposter.audiworld.com/40837/001.jpg"></center><p>....that I had previously posted about. Overall the damage did not *appear* to be that bad. I hooked up the vag-com (log is below) and was able to the car for a short drive as well. Seemed to drive fine with the exception of a shake probably due to alignment, however I never got too into the throttle and didn't take it over 40mph due to the intercooler. It did also have obivious paint/body work prior to this accident.
The guy selling seemed very knowledgable of Audis and even worked for a local dealership for a while. He makes his living repairing salvage Audis is currently working on a '05 S4 and has a B6 A4 and '00-'02 S8 that he just completed. Turns out we had some mutual friends also. However in the end, after thinking about it, I decided it wasn't for me.
Vag-Com scan results:
Saturday, 31 December 2005, 13:09:35
VAG-COM Version: Release 504.1-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G 0002
Coding: 06611
Shop #: WSC 06325
6 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17927 - Camshaft Adjustment; Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
17930 - Camshaft Adjustment; Bank 2: Malfunction
P1522 - 35-10 - - - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D56
Coding: 00160
Shop #: WSC 06325
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition; OFF
27-10 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 D
Component: B5-KOMBIINSTR. VDO D09
Coding: 02264
Shop #: WSC 00000
1 Fault Found:
01311 - Information Data Bus
37-10 - Faulty - Intermittent
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06325
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06325
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End
Address 01: Engine
Coding: 06611
Shop #: WSC 06325
6 Faults Found:
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
3 Faults Found:
Coding: 02264
Shop #: WSC 00000
1 Fault Found:
Coding: 16140
Shop #: WSC 06325
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Coding: 00115
Shop #: WSC 06325
2 Faults Found:
End
kinda makes you wonder why the current owner isn't fixing it himself...
some of those codes look like there is some serious $$$ and wrenching to be done.
i'm not suprised... its simple
he calculates what he would be willing to "not" do the work to fix it and sell it for more, puts it on ebay for that much. If he doesn't get it, he fixes it himself and sells for more.
Agreed.
Based on the codes and the pictures, it does appear he did some of the work on the car...enough to make it "presentable". But the codes seem to indicate there's a good bit of work left to be done. If he's that knowledgable about cars, he's made a decision to stop at this point and sell it unfinished. No warm and fuzzies here.
E Vader
09-26-2005 09:31 AM
