couple of pics.. I need some help here..
What is the thing located above driver side tran axle. what does it do ?
<Img src="http://pictureposter.audiworld.com/103335/olicar.jpg">
Is the a leak i see some oil on the hose..
<img src="http://pictureposter.audiworld.com/103335/olicar3.jpg">
2nd Attempt to find clutch bleeder failed.. where is it (also my car is still hot i heat hurts)
<img src="http://pictureposter.audiworld.com/103335/olicar4.jpg">
its jacked up in the driveway and its not coming down till i get this clutch bleed..
#1: Shift Linkage. #2 Chiddy pic, can't see oil. But if there's a lot of oil there, yeah
its probably leaking. See if you can find the source. If not, clean it off and check it again in a day or a week or so.
Sorry, I don't know where the bleed screw is.
ok does the shift linkage look ok? cause its really hard to shift gears and im trying
to fix it.. tried aligement twice.. new tranny fluid.. now trying to bleed...
sorry, i dunno. What exactly do you mean when you say "hard to shift"
Does the clutch disengage completely? Try shifting into reverse at idle and listen/feel for grinding - to answer this question.
Did you recently install a short-shifter? Have you checked the shifter alignment?
In general, I think the linkage is kinda an all or nothing thing. "hard to shift" doesn't really point to a linkage issue, imo. Either your pp or tob is fvcked, you have air in the system, your tranny fluid sucks, or you have a shifter alignment issue.
thx for the info man.. its hard to go in gear.. it doesnt grind in reverse just hard to get it in..
installed a rs4 clutch.. sac was fine when i took it out of the box unless mechanic messed it up with new tob.. so i should be fine..
MySTG3S4
9
12-07-2007 06:19 PM
eigenvector
10-09-2006 03:29 PM
Lilcarlson2
03-12-2006 11:11 AM
88audi90_Q
07-07-2003 05:43 PM
Stang Guy
11-04-2001 12:37 PM
