Diagnostic wizards... take a look ...vacuum/boost leak...power steering leak...
Old 03-08-2005, 12:13 PM
DBenn (Derek)'s Avatar
Default Diagnostic wizards... take a look ...vacuum/boost leak...power steering leak...
CEL came on yesterday. Got it Vag'd today. The two codes are
17535
17537
Both seem to be long term fuel trim. So it appears I have a vacuuum/boost leak some where. I noticed my PCV value is a bit loose. I hope I'm using the right name for it. The black thing are the drivers side top of the big Y pipe...kinda plugs in the side. It clicks and the o ring is in there, but it's kinda floppy.
Also, noticed I have a power steering hose leak on the passenger side. Looks like that hose runs from the front of the engine to the back of the engine. (makes sense since I had to add power steering fluid recently)
What's the next step? Hook it up to a smoker/pressure tester and see where it's leaking?
How hard is it to fix that power steering hose?
Oh..the vitals are as follows:
MTM 2+
Miltek DP
MTM exhaust
RS4 fuel pump
5 bar fpr
Old 03-08-2005, 12:21 PM
Senior Member
SAC-CA-GTI's Avatar
May be 02 sensors or MAF...do a search on the codes and you'll find what you're looking for!
Old 03-08-2005, 12:24 PM
Member
X - 1 _ r a c e r's Avatar
YGM
Old 03-08-2005, 12:35 PM
Yep, possible MAF and O2 like you said Gary. Good thing I can still get to Tahoe this weekend.
Old 03-08-2005, 12:52 PM
But I wonder about that PCV ....should it be loose like that?
Old 03-08-2005, 12:55 PM
Member
Ochlockonee's Avatar
Default The thing on the side of the y pipe is part of the pcv system, but not the valve. It's ok
if it's a little loose.
If the p/s hose you describe runs under the intake, you will have to pull the intake manifold to replace it...unless the engine is out:-(
If your car is a 2000 it may well be a maf.
Old 03-08-2005, 01:08 PM
Senior Member
SAC-CA-GTI's Avatar
Default It should be somewhat snug...I wouldn't call it loose or tight. It's hard to say since
I can't see your car! Sorry I can't help you more. But seriously, Kim here in Sac. had those SAME codes and the dealer found a bad MAF and they replaced it free. Remember we in Cali are covered under emissions till 100Kmi! MAF falls under emissions. Just hope you know someone at the dealer, like I do that would look past the mods.
Old 03-08-2005, 01:59 PM
M box..... that PS hose is more to the side I think...that can wait...more concerned with vac leak
ertatta
08-13-2009 06:40 AM
azndrunk74
03-09-2004 05:22 AM
thrash
01-18-2004 07:21 AM
quattromano
01-03-2003 05:09 AM
gjmagat
04-06-2001 08:31 AM
Quick Reply: Diagnostic wizards... take a look ...vacuum/boost leak...power steering leak...
