Did I run the wrong size tires? :(
Apparently, my tire's gone....as well as my rim.
I run Falken 225-40-18 on BBS CHs 18". Was it a too tight setting? What size tires should I go for? 235 or 245?
Tread looks ok, but only the side wall got stretched and messed up.
Now I will need four new tires and one CH.
If anyone has a CH cheap. Please let me know ASAP. Thank you.
<img src="http://pictureposter.audiworld.com/37200/dsc02257.jpg">
<img src="http://pictureposter.audiworld.com/37200/dsc02256.jpg">
<img src="http://pictureposter.audiworld.com/37200/dsc02258.jpg">
dunno, but 225/35/18's would have been closest to stock
Check this toit calculator<ul><li><a href="http://ejelta.com/tiresize/index.html?tiresize=225%2F40-17&minwidth=225&maxwidth=245&minratio= 35&maxratio=45&minwheel=18&maxwheel=18 &maxdelta=5">Next best wheel size calc</a></li></ul>
Re: Did I run the wrong size tires? :(
assuming the wheels had the proper offset, the tire size is perfect, Im guessing the tire pressure is bad or the tire is faulty,
did you hear any rubbing?
How low is the car, and have you had the alignment checked recently?
If not, I would get an alignment ASAP. Tire underinflation could have contributed, but you would have noticed some excessive outside edge tire wear. If the wear was limited to the inside edge your alignment is off. Some of that could be attributed to toe (easy to fix) while some of that may be attributed to camber (car might be dropped a lot...not much you can do short of buying adjustable control arms.
