Difference between Valeo Housing for S4 and A4? I think I got ripped off.
The Valeo Housing I have does not fit properly. Plus, I opened it up to check what kind of bulb the installer put in. Itīs a D2R bulb and the base of the headlamp is an H7 bulb base.
Arenīt S4 OEM bulbs suppose to be D2s?
One good thing is that the beam pattern seems right, but arenīt non Xenon projectors suppose to be different from non xenon projectors?
Does anyone know the difference?
Plus, the ballast installed is not mounted on the headlamp assembly. They just double tapped it somewhere in the engine compartment.
I am kindda confused. Did the shop install the wrong Euros?
Re: Difference between Valeo Housing for S4 and A4? I think I got ripped off.
If it is a HID housing, it must say D2S at the bottom of the glass, in the vicinity of the projector lens.
Re: What is the difference between D2S and D2R ???
D2S is for projector type headlamps, D2R is for reflector type headlamps. S4 has D2S. D1S/R come with igniter built into bulb instead of into ballast.
Cush
03-31-2006 02:17 PM
kk_1.8t
10-25-2004 05:31 PM
Fastfwd
03-31-2004 06:02 AM
ThirdEye
01-11-2003 10:48 PM
jason in toronto
06-14-2001 04:36 PM
