Does anyone know if the S4gives a warning if our brake pads are close to worn out?
Old 11-02-2001, 08:35 AM
New Member
Judicator's Avatar
Default Does anyone know if the S4gives a warning if our brake pads are close to worn out?
The BRAKE light on my dash has been flashing frequently as of late. Sometimes when I start the car, when I accelerate agressively and when I hit bumps.
I read the manual and it says something to the effect that the brake fluid might be low but I think the fluid level seems fine to me. Could it be the brake pads? Would it definitely be unsafe to drive like this? I can't get in for service until the middle of next week.
Thanks.
Old 11-02-2001, 08:40 AM
Andy Hedin's Avatar
Default The front pads have a sensor....but I would think if you're at that level....
...of pad left, the light would trip and then stay on. Not go on and off when you accelerate and hit bumps.
My guess is low brake fluid.
Old 11-02-2001, 08:44 AM
UnderPressure's Avatar
Default brake light?
do mean the word "BRAKE" that lights up in the instrment cluster? If so, that's your hand brake. Might be a bad/loose switch.
As Andy said, the stock front pads have a wear sensor, the pad warning looks like a (O) symbol in your information display. There is another symbol for low brake fluid warning as well. Check your manual.
Old 11-02-2001, 08:49 AM
Member
gimbal (fight on)'s Avatar
Default The pad wear indicator is displayed in the information center! It is accomanied by a audible warning
The intermittant brake light you see might have something to do with you emergency brake!
Old 11-02-2001, 08:55 AM
silvertip's Avatar
check your brake fluid level - you are possibly low
Old 11-02-2001, 09:11 AM
RR
RR's Avatar
Front pads only, yes.
Old 11-02-2001, 09:46 AM
New Member
Judicator's Avatar
Sorry for the confusion, I meant Brake warning light. Thanks for the responses.
Old 11-02-2001, 10:26 AM
vrsix's Avatar
You mean the "Ack! That scared the **** outta me!" audible warning?
Stone77
08-07-2010 12:39 PM
Toiffel
10-06-2008 07:09 PM
hili
06-14-2004 05:25 PM
2001SilverS4
04-17-2004 01:30 PM
XTrooper
03-12-2002 09:25 AM
Quick Reply: Does anyone know if the S4gives a warning if our brake pads are close to worn out?
