Does anyone know what exactly is nvolved with the 62K service? and how much of it could i do myself?
If you have a 2000 it's at 64K..... parts around $130-140 something
Spark plugs
Air filter Pollen filter Oil filter 7qt oil if you do it yourself and it's easy you can save 400-450 in dealer labor. Chris |
here is my link from many moons ago w/pic's
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1218178.phtml">https://forums.audiworld.com/s4/msgs/1218178.phtml</a</li></ul>
Service Intervals for 2000
<ul><li><a href="http://www.bentleypublishers.com/images//tech/audi/audi.2000.maintenance.sched.pdf">http://www.bentleypublishers.com/images//tech/audi/audi.2000.maintenance.sched.pdf</a</li></ul>
Service Intervals for 2001
<ul><li><a href="http://www.bentleypublishers.com/images//tech/audi/audi.2001.maintenance.sched.pdf">http://www.bentleypublishers.com/images//tech/audi/audi.2001.maintenance.sched.pdf</a</li></ul>
oil / filter /pollen filter / air filter / spark plugs / wiper inserts / tire rotation ...
check all fluids. At least thats what we do for roughly $550.
thats what i thought most of it was, but i didn't know if you have to change the trans fluid or not.
if i do the work how do i reset the service thing on the dash?
thanks alot i appreciate all the info.
Re: thats what i thought most of it was, but i didn't know if you have to change the trans fluid or
Two buttons on the instrument cluster, start with ignition off. Push & hold the right one, turn the key to on (don't start), until it displays the service info on the cluster. Release the right button, and press & hold the left until it resets. You're done.
cool, thanks :)
