Does Oettinger RZ's fit over STOPTECH brakes? more....
Why would you want to buy brakes designed for a car that has the opposite weight distribution.
Weight Distributions:
Porsche----40%/60% Front/Rear
Audi---------60%/40% Front/Rear
I think weight distribution would be a significant factor when an engineer designs a set of brakes for a car.
Porsche's have bigger brakes (rotors) in back.
As long as the combo of piston (size/number of pistons) and the rotor diameter gives the same braking torque, you're ok to switch. Then you can fine tune it by spacing the caliper further in or out along the rotor. Also using different braking pads between front and rear will help to.
C.O. Guy
9
11-15-2003 01:02 PM
