Does replacing ABS pump controller expose brake fluid?
The ABS pump controller on my 2000 S4 is starting to fail. I've searched the board and it appears to be a common failure. It looks like replacing the controller in the engine compartment usually does the trick.
My question is, does removing the controller release brake fluid or do the hydraulics remain intact? The part number on my controller is 8E0 614 111 A. Is there an updated part for the 2000 S4? |
nope, none of the hydraulics are touched, its a pretty easy swap :-)
^CORRECT^ 8E0 614 111 A - Welcome to the club, failure is inevitable.........
2 companies, one in Europe one in US know what the problem is and can repair the module.
Will 8E0 614 111 E work? Saw some on car-part.com.
No, those are for cars equipped with ESP. AutoECU.com will rebuild your module for $350/5yr warranty
Thanks, all. Gonna see if AoA fix it out of warranty, first. If not, then I'll DIY.
Whoa.. "E" is what the dealer sold me (for $1000)
"A" is the non-bled unit for oem production. "E" is the pre-bled replacement part.
<img src="http://dave-new.com/S4/ABS/ABS_NO_ESP.jpg"> |
Looks like it would work. Is it just quality tested before it's sold?
As expected, no go with AoA. Last question: Windshield reservoir removal necessary?
Hold off on sending your unit to AutoECU if you can. You should be seeing a few updates on their -
quality of work and service shortly.
