does wheel design affect brake cooling?
I would think that chunkier, more monoblock wheels (like on some A6's, and the AMG ones from MB) would make your brakes hotter b/c of less air flow (=less cooling by convection (?) when in motion, as well as holding in heat when the car is not moving, as opposed to a more open spoke design like SSR's or BBS wheels. Am I right or wrong?
Shon
Shon
Former Vendor
Well sort of.
Cooling is convective and conductive. So by virtue of there being a large block of aluminum attached to the brake, that large block acts as a sink to drain the heat away. The more mass there is, the more it heat it can absorb.
So it's actually a little more complicated to determine if one wheel has better cooling than another. If you're just concerned with convective cooling, than an open spoke design cools better than a monoblock (MAE, or AMG) style. But it's more likley that the monoblock design will cool better conductively. How the two compare against each other probably requires some in depth heat transfer analysis.
good point... aluminum wheel ~= radiator, and big radiator = good
although, as you say, you'd really have to do a simulation and/or some measurements to see how the different factors balance out
Inigo Montoya
Wheels & Tires Discussion
05-25-2006 11:22 AM
Dolphin Gray
09-13-2005 05:29 PM
Mr Pendle
27
07-15-2003 11:43 PM
