For the drags next week, could I get away with unbolting my exhaust?
STOCK system? Hrm.....
The only place you can unbolt it is at the DPs and that is REALLY REALLY loud. If you had a 3 piece borla you could just unbolt the resonator and muffler and still have a liveable sound.
Hello! You cannot unbolt it at the DPs, or you will through a check engine light...
and the mixture will be terrible, as it needs the second ox sensor to derive the mixture.
Is this the System_S4000 in Sante Fe? I thought you had a serious mechanical knowledge. If so, your blanket statement of "If anything, it runs better" is not accurate. Where did you get the idea he had an aftermarket exhaust?
There is a high end pull benefit from running less resistence, but you cannot pull your stock exhaust and expect the car to run right.
Mike S
Mike S
Check the rules for the track...
NHRA street legal state you MUST have mufflers.
Yea, not everybody obeys but with NHRA if you are driving a V8 you can do whatever you want but that does NOT hold for imports.
