Dyno results inside,,,EDIT....
Old 09-15-2006, 06:39 PM
Junior Member
jwolf::ASP S3's Avatar
Default Dyno results inside,,,EDIT....
first of all i will say this is a conservative reading dyno and i nor anyone in the shop knew what were in store for today. first pull i put down 400.8whp, new shop record at CP&T for B5S4. Second run was 402.6whp and the third one was...
<img src="http://pictureposter.audiworld.com/75479/dsc01517.jpg">
<img src="http://pictureposter.audiworld.com/75479/dsc01515.jpg">
<img src="http://pictureposter.audiworld.com/75479/dsc01519.jpg">
Torque on the last run was ~410 at the wheels, i will have all the graphs once he emails them over.
I was a very happy camper today! FWIW off the shelf AWE puts down 310-320whp on this dyno. stock puts down 170-190whp. It seems that my choices in hardware and software has really paid off
This is Nye's HP calc before AWE SMICs went in...
<img src="http://pictureposter.audiworld.com/75479/log-01-003-xxxtcdfix-xxx.jpg">
Old 09-15-2006, 06:58 PM
Banned
Mark@AutoSpeed's Avatar
Very nice Jon, glad to hear it's running well. Tell Al to call me.
Old 09-15-2006, 06:59 PM
AudiWorld Expert
Milpitas2.7T's Avatar
Good show not get to the strip!
Old 09-15-2006, 07:01 PM
Junior Member
thanks mark, ill be back at Al's tomm installing some stoptechs so ill tell him to give you a ring.
Old 09-15-2006, 07:05 PM
Junior Member
Default trying to get a midwest dragnight organized in oct. we have a gt25 car here in chicago...
so im trying to get him out, hes not a big drag racer from what ive heard, but ill drive the car if he lets me.
Old 09-15-2006, 07:19 PM
EE:OutofBounds's Avatar
Default nice...interesting that each subsequent pull, your HP went UP...as in "no heatsoak"?...........
what was the cooldown period if any between the runs? Also, what was the test cell temp and how were the fans? I'm interested to know, since every Dyno i've seen, the HP goes down with each pull as heatsoak builds in, even with AWE IC's. Also...you stated that "Off-the-shelf" AWE puts 310-320 whp on this Dyno. Is that pump gas or racegas? Not to stir anything up...but your ASP file IS an "agressive" file (which you requested). You can request a more "agressive" AWE/GIAC street file as well (im sure it would put 400 whp on that DD as well).....which makes more power than their "standard" one. Just wanted to point out.....because all the Tuners imho, can make about the same power and results, it just all depends on the "Agressiveness" of the file.
Old 09-15-2006, 07:31 PM
AudiWorld Expert
nyet's Avatar
smokin pull. grats.
Old 09-15-2006, 07:39 PM
Member
sj6sp's Avatar
Default Nice pull! Couple of ?s
Did you pull any fuel and add timing since you ran race gas? Looks a little leaner than a pump gas program...maybe due to oxygenated fuel?
Kitty Cats in?
Old 09-15-2006, 07:42 PM
DxC
DxC's Avatar
Default so ur running ASP S3 and u put down 400 when AWE puts out 320?!
what is the reason for such a big difference in power.
i got you confused with the white widebody gt28. what is his AW handle? ive been gone a while, any #s from their cars?
Old 09-15-2006, 08:03 PM
Default diff could be...Octane 100/93, unhealthy AWE car? or more important, BOOST levels (24 psi of ASP to
20 of AWE). Don't look too much into the differences between the two numbers
Quick Reply: Dyno results inside,,,EDIT....
