EBC/Hybrids Install results
Old 10-29-2004, 04:42 PM
Scourge's Avatar
Default EBC/Hybrids Install results
About a week ago I posted about the issues I ran into by running K16 hybrids on AWE software. <a href="https://forums.audiworld.com/s4/msgs/1795330.phtml">Link</a>
I'm happy to say that the AVCR install has resolved all of them. The spoolup and boost creep issues are completly gone. The car feels is waay faster now, especially between 3000-5500. One of the nice things about running AVC-R is that you can set it to run varying boost levels and duty cycles for different parts of your revband. This lets you spool up to about 1.5 bar around 2900rpm and then safely taper back to 1.3 bar towards the redline. Unlike MBC this setup doesn't taper boost up top, and if you want, you can run your selected level all the way to the redline.
Installation is a bit of a research project, but once you know which pins to tap at the ECU it's fairly straight forward.
I will post some logs a little later if anyone is interested.
My only gripe is that the "unit" looks pretty ricey and i haven't found a good place to hide it. Glovebox would work, but it's hard to tinker with settings when the headunit is all the way there.
Old 10-29-2004, 04:44 PM
Banned
Mat Indukts Lambos's Avatar
Default Congrats! I've seen those installed in the sun visors.....
Might want to consider that.
Old 10-29-2004, 05:16 PM
New Member
Magogo Gorilla : DMP's Avatar
Default well done , been thinking about AVC-R for some time now ...
did you order it online ? or local tuning shop ?
Old 10-29-2004, 05:23 PM
Elder Member
S4mig@PEB tuning's Avatar
Why do they keep banning you? Damn.
Old 10-29-2004, 05:33 PM
New Member
Default Re: Why do they keep banning you? Damn.
cuz they have nothing better to do .
their 1st issue is that i took things too far ?!? ok like who hasn't ? I've done many good things here and tried to help too
and i think their 2nd issue is that i work on S4s and i don't pay AW , which I'm game . It's getting very lame but i won't give up
Old 10-29-2004, 05:49 PM
Imolavirus@BuehnEngineering's Avatar
so you programed taper into it....but otherwise the EBC makes it so there is NO taper?
Old 10-29-2004, 06:08 PM
Senior Member
Skydive@AI's Avatar
Default Sweet...
I just picked up a Profec-B Spec 1 for a little bit of cash on eBay. I'm looking foward to trying it out.
Old 10-29-2004, 06:15 PM
Mike2kS4's Avatar
Excellent. I'm still considering this option. Which ECU wires need tapping?
Old 10-29-2004, 06:22 PM
Guest
VR_Life's Avatar
Default I can't make my mind up : APEX'i AVC-R , or Greddy PROFEC E-01 - why did you choose AVC-R ?
They both offer similar features like varying boost by RPM and throttle angle.
E-01 has a nicer UI and logging to storage card
AVC-R allows tweaking boost to Speed &amp; Gear
You are right though smells like steamed jasmin rice for sure !
Old 10-29-2004, 06:34 PM
Guest
VR_Life's Avatar
RPM, Speed, Throttle
Quick Reply: EBC/Hybrids Install results
