Engine out, other work to be done?
I'm taking the engine out to replace head gaskets. A few other things I was planning on doing include:
valve cover gaskets
power steering hoses (it's been leaking)
upgrade clutch
machine heads 40-60 thousandths
belts?
Is there anything else that I ought to do while it's out?
Thanks.
valve cover gaskets
upgrade clutch
belts?
Thanks.
valve cover gaskets
upgrade clutch
belts?
Thanks.
valve cover gaskets
upgrade clutch
belts?
Thanks.
valve cover gaskets
upgrade clutch
belts?
Thanks.
valve cover gaskets
upgrade clutch
belts?
Thanks.
Motor mounts
Turbos
Snub mount
Timing service kit
Starters are a PITA, i'm doing a new one with my engine pull
Engine "O" ring kit
Former Vendor
Yikes, if you're going to go through that much work there'a a long list of stuff that should be changed..
Head gasket
Head bolts
Valve cover gasket
Cam tensioner seals
Cam seals
Cam plugs
Exhaust Manifold gasket
intake manifold gasket
valve stem seals
downpipe gaskets
valley gasket
secondary water pump hoses
coolant pipe o-rings
spark plugs
timing belt
water pump
thermostat
serpentine belt
motor mounts
snub mount
coolant
oil
Head gasket
Head bolts
Valve cover gasket
Cam tensioner seals
Cam seals
Cam plugs
valve stem seals
downpipe gaskets
valley gasket
spark plugs
timing belt
water pump
thermostat
serpentine belt
motor mounts
snub mount
coolant
oil
Head gasket
Head bolts
Valve cover gasket
Cam tensioner seals
Cam seals
Cam plugs
valve stem seals
downpipe gaskets
valley gasket
spark plugs
timing belt
water pump
thermostat
serpentine belt
motor mounts
snub mount
coolant
oil
Head gasket
Head bolts
Valve cover gasket
Cam tensioner seals
Cam seals
Cam plugs
valve stem seals
downpipe gaskets
valley gasket
spark plugs
timing belt
water pump
thermostat
serpentine belt
motor mounts
snub mount
coolant
oil
Thanks for the responses. I was just thinking of things that can't be done with the engine in such as clutch, head work, etc. I've only got 50K on the car so some of the other front-end stuff can wait for now.
Speaking of heads, does anyone make a good head stud set for the 2.7? ARP doesn't seem to make any.
