Sponsored by:
Sponsored by:
Engine sound of S-4 after cold start
Old 06-04-2001, 02:54 AM
New Member
Default Engine sound of S-4 after cold start
Anyone know why the engine almost sounds like a truck when starting up after sitting overnight. It goes away about 40 seconds later when rpms settle to about 750-800 rpms.
msr711 is offline
Old 06-04-2001, 03:12 AM
Member
Default Probably oil drains out of the lifters and it takes a minute or so to pump them back up.
I can't judge the noise level from your message, but it could be a bad/leaking backflow valve in your oil filter. Not a serious problem, if that's it. Some clatter at start is normal.
Jim De Arras is offline
Old 06-04-2001, 03:48 AM
New Member
Default Re: Probably oil drains out of the lifters and it takes a minute or so to pump them back up.
thanks
msr711 is offline
Old 06-04-2001, 04:47 AM
RR
Default Make sure you use the OEM (Audi) oil filter. It's common for the jiffy-lube brand to leave out
the one way valve that keeps oil in the engine when it's shut off.
It sounds bad, but my Nissan pick-up has the same problem and it's survived several years so far.
I thought about installing a pre-luber pump...but it's hard to justify for a $500 truck.
RR
RR is offline
Old 06-04-2001, 11:02 AM
Default I had this...
when the car was brand new, about every third start or so, from delivery miles (130) until I changed it (mobil 1 0-30) at 2800. the clatter in my case was defintely the lifters bringing up pressure. after i changed the oil it went away for a while, now it's back.
BUT, mine lasts only for a second or so- when i first start the car up the revs quickly go to 1800 or so, and by the time the engine is slowing down everything is normal. i would say 40 seconds of lifter clatter is VERY long... it bugs me, but i've been told by my service advisor that i shouldn't worry...
UberVier is offline
A6 Jesse
02-20-2005 01:18 AM
bshin80
09-17-2004 01:41 AM
hkphooey888
09-17-2003 08:19 AM
Hawaiiannights
12-13-2000 06:02 AM
Randall Ryder
01-15-2000 05:53 AM
Quick Reply: Engine sound of S-4 after cold start
