Error code and MAF question
Old Jan 28, 2003 | 09:52 PM
Cipher5170's Avatar
New Member
Default Error code and MAF question
The car is throwing a code (forgot the exact #) but it says "MAF sensor signal too low". last time I interpreted that as a failure and just replaced it. Is it possible that the sensor is just dirty? Someone said that I can just clean it with isophryl alcohol. How do i go about that? Just dip it in or what?
This is the the second time this has happened. Ever since I installed the S-flo AWE filter I've had MAF problems. I'm driving and accelerating hard and it feels like the car hit a wall for a sec and then all is fine. When I restart the code pops up.
Your input is appreciated
Thanks to all audi enthusiasts
Old Jan 28, 2003 | 09:58 PM
Cipher5170's Avatar
New Member
Default 16486 MAF Sensor (G70): signal too low
that's the code
Old Jan 28, 2003 | 10:05 PM
Kent L's Avatar
Senior Member
Default Could try cleaning the MAF...
Remove the sensor from the housing and splash it in some 90%+ rubbing alcohol and let dry.
Old Jan 28, 2003 | 11:10 PM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default Can you just pull the mesh ring out?
Or do you dip the mesh with the plastic..? :-/
Old Jan 28, 2003 | 11:43 PM
Kent L's Avatar
Senior Member
Default Hmm. Pretty certain you can't separate the hotwire from the sensor housing.
That 'mesh ring' you refer to is the debris screen.
Old Jan 29, 2003 | 09:05 AM
B Lee's Avatar
New Member
Default I just went through 3 weeks of trying to figure out my MAF problems too.
Did a search on the forum and found a bunch of posts on cleaning the MAF, either with Isopropal (>91%) or an ELectronic Cleaner. Tried both methods, with my stock chip back in. Never worked, although some posts claimed it can work. I also had problems the day after installing a pre-oiled ITG drop in filter. I think the oil on the filter is contaminating the MAF sensor, which I heard is not a high quality part to begin with. IN the end, nothing seemed to work. I was also getting intermittent boost problems, cylinder misfiring, and low air flow codes. I re-installed the stock paper filter but the 2 cleaning methods still failed to eliminate the boost problems (car was probably going into limp mode). In the end, the dealer replaced my MAF for free under California's 7/70 emission warranty, which I had no idea about until I brought the car in and the dealer told me.
pentosinjunky
Mar 30, 2008 04:51 PM
BluHeaven
Jun 17, 2006 03:47 AM
duodallas
VAG-COM Discussion
May 9, 2006 04:37 PM
skl1
Nov 22, 2003 02:15 PM
