Need help with suspension installation. Putting in my stasis street sports, and I got three corners
done, and on to the drivers rear. When disconnecting the upper control arm, I took the nut off, and it seems like the bolt is seized into the uprights. Need some suggestions to get it out. It is the bolt in the upper control arm on the rear driver suspension that you remove to take the rear coilover out of the car. Thanks
Update: Got the bolt out. Thanks for the help guys. The bolt was binding pretty bad, but jacked
it up and hit it with the impact wrench a few times, then hit it with a hammer and finally got it spinning so I could get it out. Thanks alot!
Mike O.
12-11-2006 04:22 PM
CMS4 II
10-07-2006 06:48 PM
ross@downforce.net
09-30-2002 11:21 AM
