fault codes
fault codes
i just ran vagcom on my car
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Wednesday,23,November,2011,16:07:36:44919
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 00060
VCID: 34691EDC042070E
11 Faults Found:
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-00 - Voltage too Low
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
17530 - Oxygen (Lambda) Sensor Heating; B2 S2
P1122 - 35-10 - Open Circuit - Intermittent
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 35-10 - Internal Resistance too High - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
P1118 - 35-10 - Open Circuit - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-10 - - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C39D67C8CB0D8E
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00160
Shop #: WSC 06325
VCID: 2D5F0BB8E70A216
2 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-00 - Open or Short to Plus
00779 - Outside Air Temp Sensor (G17)
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06325
VCID: 3A7530E4264486E
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 05701
VCID: 2B5B05A0D91E2F6
2 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01315 - Transmission Control Module
49-00 - No Communications
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06325
VCID: 4081420C4098DCE
3 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
VCID: E0C1228C60583CE
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
VCID: E5CF33987F7A596
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00115
Shop #: WSC 06325
VCID: 2449EE9CB4C0E0E
End ---------------------------------------------------------------------
any ideas?
Coding: 06711
Shop #: WSC 00060
11 Faults Found:
16688 - Cylinder 4
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
2 Faults Found:
Coding: 00304
Shop #: WSC 06325
Coding: 02264
Shop #: WSC 05701
2 Faults Found:
Coding: 16140
Shop #: WSC 06325
3 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00115
Shop #: WSC 06325
any ideas?
i cleared codes and rescaned and got
Wednesday,23,November,2011,16:20:32:44919
Coding: 06711
Shop #: WSC 00060
1 Fault Found:
Readiness: 0110 0101
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
Coding: 02264
Shop #: WSC 05701
1 Fault Found:
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00115
Shop #: WSC 06325
Coding: 06711
Shop #: WSC 00060
1 Fault Found:
Shop #: BB 24334
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
Coding: 02264
Shop #: WSC 05701
1 Fault Found:
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00115
Shop #: WSC 06325
2point7LI
12-29-2006 05:29 AM
Longwolf (Christian)
Florida Discussion
04-23-2006 05:03 PM
BeeRock::Riding Red
VAG-COM Discussion
01-22-2006 10:00 PM
