First FATS run on Stage 3
Old 04-16-2005, 09:06 PM
Member
sj6sp's Avatar
Default First FATS run on Stage 3
<center><img src="http://pictureposter.audiworld.com/31992/fats.jpg"></center><p>Calculates to 3.93 seconds using MarkP's spreadsheet.
I'm using Autospeed's 85mm MAF Housing so the values are scaled down a bit.
Software is AMD/ASP's Beta K04 code running only 15-16psi.
40F, Jersey's finest 93 Octane.
I have to say that I'm very pleased how fast the car is at the low boost and Mark's efforts to make sure I'm happy with the end product. Can't wait to inch up the boost a wee bit more.
Old 04-16-2005, 09:08 PM
[badmoon]'s Avatar
Wow, that's impressive. What other mods do you have?
Old 04-16-2005, 09:14 PM
Member
sj6sp's Avatar
Default Doh, I've been working on a sig pic and deleted my list....
Engine performance related mods are
RS4 K04s
ASP/AMD beta software
Forge 3" single
ASP DPs w/ cats. Testpipes waiting to be installed
ASP Phenolic spacers
AWE ICs
ASP 85mm MAF
42lb injectors
Elder Member
PSmalls::DoggieStyle's Avatar
Very nice timing!
Old 04-16-2005, 09:19 PM
AudiWorld Expert
Captain Matt, I be's Avatar
awesome man, im impressed. running straight K04s?
Old 04-16-2005, 09:20 PM
Member
sj6sp's Avatar
Default I was surprised by the timing too.
I wonder if I can keep it that high and run higher boost.
Old 04-16-2005, 09:23 PM
Member
sj6sp's Avatar
Yup. Standard RS4 K04s
Old 04-16-2005, 09:34 PM
Mike2kS4's Avatar
Default Wow, gotta love low boost for some serious timing #'s ;)
Well, the ambient temp helps too
Old 04-16-2005, 09:40 PM
Tomasz@Startup's Avatar
Default Wow, that looks good.
I know that Mark is inching up the boost a little on my car. Exhaust manifolds should help a little too. This will be fun!
Tomasz
Old 04-16-2005, 09:53 PM
AudiWorld Expert
nyet's Avatar
Default nice pull, can you send me a .csv? i'll plot up a hp estimate for you...
send alt/humidity if you have it etc.
sub 4 fats is usually high 300's whp. good show..
Quick Reply: First FATS run on Stage 3
