foglight mod - quick question
I am about to perform the foglight mod (following instructions in the tech section of this website). Here is my question. I live in an apartment and park far from a electrical outlet. Once I expose the foglight relay, is it easy to remove, take up to my apartment to do the soldering, and then reinstall? (i.e., is there a wiring harness I can just pull, or do all the wires run straight into the box). Thanks in advance.
caution...
removing the relay module is <i>easy</i>. Here's a pic of the relay module...
<img src="http://pictureposter.audiworld.com/22702/foglt_relay.jpg">
...just remember <b>not to over do the soldering</b> to jump pins 14, 15, 17 like so...
<img src="http://pictureposter.audiworld.com/22702/foglt_rly_top.jpg">
...or else....
...or else....
Its a lot easier the second time you've done it.
I managed to pop apart the socket under the dash the last time I did it (the socket came detached from the clip that holds it in place), but some crushed knucles and angry swearing was all it took to get it back together.
