forgot to mark precat before cutting piggies
yeah i totally forgot to mark the precat position before cut it, i can kinda line it up because i cut from both sides so you can line it up where each cut ends, but it still is probably off by a little. is this a big deal? does it pretty much have to be exact same for it to fit?
Re: has to back in the same spot.... there is such a complex twist on the pipe that it needs to be
i guess i could mabye do like 2 little welds and if it doesnt fit just do it over till it fits again. or is there any way i can be sure its right on?
aren't there any marking on the pipes (scratches, stretch marks from original bending) that can
assist you in getting them back into the proper angle? even maybe looking at your cut marks to get some common points...
starting ...
05-30-2006 11:18 AM
