Front to rear weight balance, stock? after stripping interior? questions!
Howdy!
Question: when i have tracked my S4 (Stasis TrackSport Suspension), it feels moderately unstable under braking. I am attributing some of this to the front weight bias of the car.
What is the F/R balance from the factory?
For those that have stripped interiors, removed spare tires etc, doesn't this further increase the weight bias to the front?
What is the F/R balance after stripping the car?
And who is the king of 50/50 weight distribution?
Did it significantly improve track performance?
Alright, enough theoretical questions...start flaming!
Mine always shimmies a little under heavy braking. I attribute it to minute differences
in traction, brake surface, etc. I don't really worry about it.
Now, if you're swapping ends regularly, then you have a problem, but I bet it's not with weight distribution.
somewhere around 60f/40r avants are like 1% more shifted to the rear.
oh and BMW is king of the 50/50 distro.
Rear brakes could be going away faster than fronts... something to think about.
And 60/40 is about the best weight dist. you'll get without adding ballast to the rear of the car. Other brands have better weight distribution, but that doesn't seem to matter much for the last half of the corner when we can just lean into the loud pedal and run away.
gut everything you can, move battery and anything else as low and far back as you can
an then add ballast in the spare tire area with lead to get back to stock weight yet be at a true 50/50
RedS4inPA
03-23-2007 02:49 AM
AudiOx
09-17-2002 08:42 AM
jyoteen
15
06-29-2001 07:32 AM
