Fuel Injector Question
My car is in the dealer right now getting upgraded with k04's They asked me if I wanted the RS4 fuel pump and RS4 injectors. They gave me such a good price on the parts and installation i said yes. What I am wondering is should I just get the fuel pump and hold off on the injectors? Reason being is I want to run stage III software and I am not sure if the RS4 injectors will supply enough fuel for the job. I am also going to be using the 5 bar PFR .. Please let me know what you think.
You mean flow rates i think, and they vary with each kits injector choices...
Matching the injectors to the ECU tuning is critical btw. And the 5 bar may or may not be necessary depending on which stage 3 you select...
Re: You need to figure out whos stage 3 kit you're going to run before you do either, IMO..
This is sort of my own stage III kit ... I want to run GIAC software but they don't make it for the TIP so I might have to use someone elses.. I just want the car ready for when that time comes..
