Gas odor after filling up?
not sure why youre smelling that...but I can tell you what it’s not...
virtually any gas leak in that system will cause a check engine light. Even if you leave your gascap loose, you’ll get a check engine light.
I’d try filling the car only 1/2 way up and see if you smell it.<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/carssmall4.jpg">
00 S4 tip
Silver/Onyx
GIAC ECU/tip “race” chip (14.4 in 100 degrees)
V1
00 S4 tip
Silver/Onyx
V1
That's funny, because I put in every little last drop that can be retained (read overflow puddle)
<p><a href="http://www.jyoteen.com"><img src="http://www.jyoteen.com/audiworldsig/rips4.gif" border="0"></a>
Get it checked!
I had a fuel leak at the gas tank and and there was never a check engine light.
The dealer said the leak was due to a rolled seal at the fuel sending unit.
A forum search showed a couple others apparently experienced the same problem.
I had that too
The gasket at the fuel gauge sending unit was folded over, and leaking. Check under your car and see if you have gas on the plastic cover just ahead of the rear axle. If you do, you probably have the same problem. Depending on how bad it is, you may or may not see the check engine light.
ECD212 Reborn
11-21-2004 12:44 AM
MikeNSX
Audi 100 / A6 (C4 Platform)
04-16-2004 09:36 AM
Nupeskee
09-08-2000 02:27 PM
