Going Stage 3- question about piggies
So, I decided to replace the K03s with K04s, sounds like a better thing in the long run anyways.
So, here is the main question... should I definitely get the piggie pipes while getting this done, or not really necessary. Budget is of concern.
You mean the wires? Mine did. It depends on where you relocate them.
If you do it the way Piggie(I copied his) and I did them they will fit. I did not install the pipes, but I assume my installer just cut the wire ties and relocated the wires. I think its a stretch but it works. If you want to spend the money, I suggest the Zoldman O2s. They are high quality and are plenty long. You can buy them through Vast Performance. I was cheap and kept them stock...so far so good :-)
A4by4
06-27-2001 05:37 PM
exs4owner
05-18-2000 05:57 PM
